Unusual Card Reader Behaviour.
I don’t know how in hell it’s happened but my SD card reader doesn’t seem to work right with my laptop.
As I plug it in, the red light comes on for power, but the green light which indicates when a memory has been put in, comes on when there’s no card in it. Yet if I plug it into my PS3 it doesn’t do it? I don’t understand what’s happening and if at all possible, please help. >.<
EDIT: Ok now it’s not doing it. Seems to be some issue with the USB cable. :S I changed it from the PS3 cable to my digital camera cable.
Have you tried it in different USB ports ?
is it a USB card reader ?
Have you tried having the card/reader inserted when you turn the PC on?
if you pug it in whilst the PC is booted, then just after plugging it in, run
dmesg | tail -n 20
are there any clues ?
Read my edit. Seems to be the USB cable.
Just for safety’s sake…
dbally@bally-laptop:~$ dmesg | tail -n 20
[ 1097.070240] usb 5-1: new full speed USB device using uhci_hcd and address 4
[ 1097.227310] usb 5-1: not running at top speed; connect to a high speed hub
[ 1097.264826] scsi6 : usb-storage 5-1:1.0
[ 1098.264418] scsi 6:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 1098.267378] scsi 6:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 1098.271392] scsi 6:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 1098.274365] scsi 6:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 1098.275640] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 1098.276087] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 1098.276524] sd 6:0:0:2: Attached scsi generic sg4 type 0
[ 1098.276937] sd 6:0:0:3: Attached scsi generic sg5 type 0
[ 1098.302347] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 1098.328335] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 1098.333342] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[ 1098.338329] sd 6:0:0:3: [sde] Attached SCSI removable disk
[ 1241.535429] sd 6:0:0:0: [sdb] 1950720 512-byte logical blocks: (998 MB/952 MiB)
[ 1241.540725] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1241.550565] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1241.556540] sdb: sdb1
[ 1247.546462] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Ahh … I must have missed the edit :slight_smile:
