I just installed Metacity desktop and rebooted. The result was no internet access as before so I repeated the actions we’ve done and am back on line straight away.
When I did apt install systemd-resolved --fix-missing part of the response was:
Configuration file ‘/etc/systemd/resolved.conf’
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** resolved.conf (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/systemd/resolved.conf …
Converting /etc/resolv.conf to a symlink to /run/systemd/resolve/stub-resolv.conf…
Created symlink /etc/systemd/system/sysinit.target.wants/systemd-resolved.service → /usr/lib/systemd/system/systemd-reso
lved.service.
Processing triggers for dbus (1.14.10-4ubuntu4.1) …
Processing triggers for man-db (2.12.0-4build2) …
root@E5570:/home/keith#
where I opted to install the package-maintainer’s version of /etc/systemd/resolved.conf and it worked fine. It remains to be seen if a reboot fails again, but I’ll report back. So far, though, all looks well.
I can’t begin to really understand what I’ve been doing, and I am really grateful for your help.
