I have a shield symbol that tells me there are 169 updates to download but, when I try to download them I get an error message stating that not all updates could be downloaded.
When I close that the shield remains with 169 updates still there.
Reading package lists… Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 200 not upgraded.
After next three commands
Configuration file `/etc/issue’
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** issue (Y/I/N/O/D/Z) [default=N] ?
Warning: No support for locale: en_GB.utf8
mint-flashplugin-11
E: Sub-process /usr/bin/dpkg returned an error code (1)
dpkg: error processing mint-flashplugin-11 (–configure):
subprocess installed post-installation script returned error exit status 2
mint-flashplugin-11
Setting up mint-flashplugin-11 (11.2.202.280) …
update-alternatives: error: unable to read link `/etc/alternatives/libflashplayer.so’: Invalid argument
mint-flashplugin-11
