Updating Zorin OS
Hi All - I’m attempting to configure Update Manager in Zorin but have hit a couple of snags.
1 Update Manager informs there are updates available but doesn’t list them (upper section is blank)
2 When using Terminal commands ‘sudo apt-get update && sudo apt-get upgrade’ it stalls at this -
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
As far as I can see, no other processes are running… (I think this error usually generates if Synaptic is open, but I could be wrong?) ::slight_smile:
Any clues?
OOPS!!! Please ignore point #2… Synaptic was running…!! Senior moment :-[ :-[
Cheers
Rich
Double OOPS!! Update has cured issue #1 too… :-[ :-[ :-[ I really shouldn’t get up so early…
Have a nice day everyone! ;D
I thought I was reading one of my posts for a minute there, glad it doesn’t just happen to me :stuck_out_tongue:
You are taking my Crown of asking and then answering my own questions.
I wont go down without a fight! :wink:
