Virtual DJ for LinuxnMint 19.1
Hello all, I am trying to find and download Virtual Dj for linux but cannot find it or similar. Basically, I am looking for a DJ application like Serato Dj, Virtual Dj or CrossDJ. I know that the above names might not be available on linux but I am trying to find alternatives. Could any one please suggest some and where to download them from?
Appreciating your response in advance
Sabinus
How about Mixxx and/or TerminatorX
They’re in the default repos … to install just run:
sudo apt-get install mixxx
and/or
sudo apt-get install terminatorx
websites
and/or
https://terminatorx.org/
There is also BpmDJ
http://bpmdj.yellowcouch.org/index.html
but that requires Java, and isn’t in the default repos.
Or depending on what you’re trying to do, maybe just audacity would do
which is also in the repos
sudo apt-get install audacity
Mark Greaves, You are a star. Thank you very much. I have been able to install both and can see them in my Linux Mint 19.1 (Cinnamon) system.
Mixxx seems to have a great user manual linked at the top of their homepage
https://www.mixxx.org/manual/latest/
which can also be downloaded as a pdf
https://www.mixxx.org/manual/latest/en-GB/Mixxx-Manual.pdf
and a support forum
Not bad for free eh! :slight_smile:
