Virtual Machine software
Evening all,
I am coming to the end of my patience with Virtualbox on my machine. I have used VB for a long time to test security and play around with new distros but I always have a really annoying problem.
A lot of the time when I start up VB and try to start one of my machines it comes up with an error saying I need to reload the modules. I do this but to no success, the same issue. Some times there is no problem at all and my machines just start, or they will start after I reload the modules once.
This is something I’ve put up with for a long time and I’ve scoured the internet to try and find a solution. I’ve also used different distros and reinstalled my machine a couple of times.
To be honest I haven’t found a permenant solution so I think it’s time to move on.
The point of this topic is to ask what Virtual Machine software everyone uses and if they could recommend one for me. I have looked at others but I’d like your input.
Thank you all for your input!
I tend to use Vbox too, and I agree it tends to be a little unstable.
I’ve tried VMware player, which was very recource hungry whilst a VM loaded, but then ran OK.
I haven’t got a CPU that supports hardware accelerated virtualisation … but it you have, why not just give kvm/virt-manager a go ?
I tend to use Vbox as well, though I have dipped my feet in with VMware. Like Mark, found it to be a little resource hungry when loading a VM but then it ran fine.
I think what I might do is make a list of common CPU’s that support HAV.
Update :
VirtualBox still lives and in good shape,
Many of the problems have been fixed and it supports more OS now.
