Webrowsing on Chrome issue (Solved)
Hi
When i open Chrome the chrome window itself opens to full screen size but when i open a webpage it seems to be a4 size and centred , the Text is small
also as if it is set to default
Any thoughrs please
mint 15 64bit
In any of the following web browsers … Chrome/Chromium/Firefox …
Hit Ctrl+“+” … to enlarge text
Hit Ctrl+“-” … to shrink text
You can also hit Ctrl, and whilst holding it, use the mouse scroll wheel to shrink/enlarge text
wow thanks ;D
Can i ask a simple Question
Is there a Better Rep to mut my music on rather than Bansee it just keeps freezing and as far as im aware there isnt a Fix for it
??? ← That’s me looking confused :wink:
If you mean is there a better music player than Banshee … YES … Clementine
Which distro/version are you running again ?
mint 15 deb version
Check if it’s in the default repos then.
It should be in the Mint 15 normal edition … not sure about the Debian Edition.
I think there might be some confusion here.
Mint 15 is based on Ubuntu.
LMDE (Linux Mint Debian) is version-less. The nearest to versioning is the update packs (latest being 6)
found it thanks
