Where do I find GEDIT? [SOLVED]
I am using Mint 17.3 Rosa and want to use GEDIT. I have checked in the Software Manager and it says that it is installed but where do I find it? I have searched in all the likely places but I cant get it - nowhere to be found! Any ideas, please?
Hi ahead,
I go to ‘Menu’ > ‘Accessories’ > ‘Text Editor’ and voila’ there it is.
take care
Don W
BTW I use Peppermint 6
Or, open a Terminal and input: gedit
To find the path to the executable use the command: which gedit
I’m not sure 100% sure Mint uses gedit as its default text editor any more, they may have changed to pluma or xedit … you should be able to find out what text editor they’re using by default by looking for “Text Editor” in your menus, then clicking “Help > About”
If when you run:
gedit
in a terminal it doesn’t open … install it with:
sudo apt-get install gedit
Thank you, all sorted now with your help!
