I have installed Peppermint 5 on this machine but I only have a Windross disc that came with the Epson SX130 Printer/Scanner.
Where can I download the Linux drivers.
Don W
Don W
Output from:
uname -a
please.
I’m getting a real sense on deja vous here
don@ldwatson ~ $ uname -a
Linux ldwatson 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15 03:51:12 UTC 2014 i686 i686 i686 GNU/Linux
don@ldwatson ~ $
Is this what you want ?
My grandson was using this machine in Win 7 and when I shut down there was 32 updates.
I would like to remove all trace of windross and just run Peppermint. Shall I start a new thread in Peppermint Forum.
Don W
probably best
As for the SX130 drivers … I’d expect these to still work:
http://linuxforums.org.uk/index.php?topic=11487.msg92257#msg92257
hence my “deja vous” comment
I have downloaded the first line but I get a 404 error not found
Don W
OK, gimme a sec
OK, try these links … and install them in this order too:-
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
iscan-data_1.29.0-2_all.deb
iscan_2.29.3-1~usb0.1.ltdl7_i386.deb
I have installed the printer and printed an impressive test page.
Thank you again.
Don W
PS I will use the thread I started in Peppermint if I have any problems.
Great … and you’re welcome.
Please remember to mark the topic (SOLVED) if you consider it so … you can do this by editing the FIRST posting in this topic and changing:-
Subject: Where do I get drivers for an Epson SX 130 (SOLVED)
Thanks in advance
Where can I get the 64 bit drivers for this Epson SX130 ?
When I use these drivers the first says , after installing, “Broken Dependencies”
Thanks Mark,
I have carried out the above instructions and printed the test sheet, all is well.
Thanks again.
Are you running a firewall ?
I don’t think so ?
Sorry, I must have added that accidentally … it was meant to go elsewhere :-[
:-X
