Wi-Fi not working mint 17.3 (Resolved)
I am using mint 17.3 64bit mate.
My Laptop (Samsung R60 plus) - I normally connect to the internet via a cable connection so was surprised when I took the laptop to a conference and found the wi-fi adaptor was not recognised by the system.
I presume this is a driver issue how do we address the problem?
Thank you in advance.
What’s the output from:
lspci -vnn | grep -i net
lsusb
sudo lshw -C network
rfkill list
ifconfig
iwconfig
iwlist scan
Have just noticed the WiFi indicator light is not on.
usertwo@usertwo-R59P-R60P-R61P ~ $ lspci -vnn | grep -i net
02:00.0 Ethernet controller [0200]: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) [168c:001c] (rev 01)
05:00.0 Ethernet controller [0200]: Marvell Technology Group Ltd. 88E8039 PCI-E Fast Ethernet Controller [11ab:4353] (rev 15)
usertwo@usertwo-R59P-R60P-R61P ~ $ lsusb
Bus 002 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
usertwo@usertwo-R59P-R60P-R61P ~ $ sudo lshw -C network
[sudo] password for usertwo:
*-network
product: AR242x / AR542x Wireless Network Adapter (PCI-Express)
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlan0
version: 01
serial: 00:1b:9e:66:a1:b6
width: 64 bits
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath5k driverversion=3.19.0-32-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bg
resources: irq:17 memory:d0100000-d010ffff
*-network
product: 88E8039 PCI-E Fast Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:05:00.0
logical name: eth0
version: 15
serial: 00:13:77:5c:61:02
capacity: 100Mbit/s
width: 64 bits
capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.0.10 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:27 memory:d0200000-d0203fff ioport:a000(size=256)
usertwo@usertwo-R59P-R60P-R61P ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
usertwo@usertwo-R59P-R60P-R61P ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr 00:13:77:5c:61:02
inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::213:77ff:fe5c:6102/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5817 errors:0 dropped:0 overruns:0 frame:0
TX packets:4342 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5258761 (5.2 MB) TX bytes:689939 (689.9 KB)
Interrupt:18
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:754 errors:0 dropped:0 overruns:0 frame:0
TX packets:754 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:200167 (200.1 KB) TX bytes:200167 (200.1 KB)
wlan0 Link encap:Ethernet HWaddr 00:1b:9e:66:a1:b6
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usertwo@usertwo-R59P-R60P-R61P ~ $ iwconfig
eth0 no wireless extensions.
wlan0 IEEE 802.11bg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
lo no wireless extensions.
usertwo@usertwo-R59P-R60P-R61P ~ $ iwlist scan
wlan0 No scan results
does running:
sudo rmmod ath5k
sudo modprobe ath5k nohwcrypt=1 no_hw_rfkill_switch=1
kick wireless into life ?
if not, is there any output from:
dmesg | grep ath5k
Wi-fi still not working.
Read out -
usertwo@usertwo-R59P-R60P-R61P ~ $ dmesg | grep ath5k
[ 19.214597] ath5k 0000:02:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 19.214790] ath5k 0000:02:00.0: registered as ‘phy0’
[ 20.157084] ath5k: phy0: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
[ 5011.623522] ath5k 0000:02:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 5011.623783] ath5k 0000:02:00.0: registered as ‘phy1’
[ 5012.160202] ath5k: phy1: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
[ 6061.289834] ath5k 0000:02:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 6061.290070] ath5k 0000:02:00.0: registered as ‘phy2’
[ 6061.817255] ath5k: phy2: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
Also found the following file on the system - blacklist-ath_pci.conf /etc/modprobe.d this has the following content -
For some Atheros 5K RF MACs, the madwifi driver loads buts fails to
correctly initialize the hardware, leaving it in a state from
which ath5k cannot recover. To prevent this condition, stop
madwifi from loading by default. Use Jockey to select one driver
or the other. (Ubuntu: #315056, #323830)
blacklist ath_pci
Is this having an impact?
Can you REBOOT then post the output from:
dmesg | grep ath5k
again.
and the output from
lsmod
Ignore if you’ve already tried this -
Hitting Fn key then F9 toggles the W LAN on this model. If the indicator led lights up, click on Network Manager and check if everything looks correct in there - there are options to ‘always connect to this network’ etc.
Plus, there’s a manual available from - Support for NP-R60 SAMSUNG
Hope this helps
Rich
[ 20.051932] ath5k 0000:02:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 20.052889] ath5k 0000:02:00.0: registered as ‘phy0’
[ 20.743208] ath5k: phy0: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
usertwo@usertwo-R59P-R60P-R61P ~ $ lsmod
Module Size Used by
bnep 20480 2
rfcomm 69632 4
bluetooth 491520 10 bnep,rfcomm
snd_hda_codec_realtek 86016 1
snd_hda_codec_generic 69632 1 snd_hda_codec_realtek
arc4 16384 2
snd_hda_codec_hdmi 53248 1
snd_hda_intel 36864 4 snd_hda_codec_hdmi
snd_hda_controller 32768 1 snd_hda_intel
snd_hda_codec 143360 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
binfmt_misc 20480 1
snd_hwdep 20480 1 snd_hda_codec
snd_pcm 106496 4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
ath5k 151552 0
ath 32768 1 ath5k
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
mac80211 720896 1 ath5k
snd_rawmidi 32768 1 snd_seq_midi
snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi
cfg80211 532480 3 ath,ath5k,mac80211
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 32768 2 snd_pcm,snd_seq
coretemp 16384 0
snd 86016 17 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
soundcore 16384 2 snd,snd_hda_codec
joydev 20480 0
dm_multipath 24576 0
serio_raw 16384 0
scsi_dh 16384 1 dm_multipath
shpchp 40960 0
i2c_piix4 24576 0
parport_pc 32768 0
ppdev 20480 0
lp 20480 0
mac_hid 16384 0
parport 45056 3 lp,ppdev,parport_pc
dm_mirror 24576 0
dm_region_hash 24576 1 dm_mirror
dm_log 20480 2 dm_region_hash,dm_mirror
pata_acpi 16384 0
hid_generic 16384 0
usbhid 53248 0
hid 110592 2 hid_generic,usbhid
amdkfd 81920 1
amd_iommu_v2 20480 1 amdkfd
radeon 1556480 2
psmouse 118784 0
i2c_algo_bit 16384 1 radeon
ttm 94208 1 radeon
pata_atiixp 16384 0
ahci 36864 2
drm_kms_helper 131072 1 radeon
libahci 32768 1 ahci
drm 344064 5 ttm,drm_kms_helper,radeon
sky2 61440 0
video 20480 0
Does running:
sudo rfkill unblock all
make any difference ?
No difference still no Wi-fi.
I have noticed that the use of a programme called JOCKEY is recommended as an answer to this issue.
madwifi from loading by default. [b]Use Jockey to select one driver
or the other. (Ubuntu: #315056, #323830)[/b]
I have downloaded the software from Jockey (Linux) Download: Driver manager.
In case this is a viable option.
It’s not a problem with madwifi, the madwifi driver ceased to exist in 2007 and was superseded by ath5k and ath9k.
As I’m not really seeing a problem other than your wireless not seeing any networks, are you sure
a) the antenna lead hasn’t come off the adapter
and/or
b) your router isn’t broadcasting in say the 5GHz band which the adapter doesn’t support ?
I used an old D-Link USB wi-fi DWL-G122 802.11g adaptor and that works fine.
I will see if I can find out where the antenna lead is located and take a look-see… removed the wi-fi card cleaned all contacts reinstalled and attached antenna cable.
After a lot of reading on the net I found a BIAS setting to switch on wi-fi permanently the wi-fi light is now on but still not scanning for wi-fi networks…
So now here is the readings from your first post with the adaptor switched on…
*-network
physical id: 0
logical name: wlan0
version: 01
width: 64 bits
configuration: broadcast=yes driver=ath5k driverversion=3.19.0-68-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bg
*-network
physical id: 0
logical name: eth0
version: 15
capacity: 100Mbit/s
width: 64 bits
Soft blocked: no
Hard blocked: no
RX packets:1928 errors:0 dropped:0 overruns:0 frame:0
TX packets:1127 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:543312 (543.3 KB) TX bytes:169243 (169.2 KB)
Interrupt:18
RX packets:357 errors:0 dropped:0 overruns:0 frame:0
TX packets:357 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:56569 (56.5 KB) TX bytes:56569 (56.5 KB)
I think this was resolved once I found the setting in the BIAS as it would seem that the problem is the wi-fi adaptor in that just by chance I moved the laptop into the same room as the modem and hay-presto I had a wi-fi signal.
Strange that it is just this lap-top that is not getting a signal and thanks for all your help.
Which could mean the antenna has come off the wireless adapter :wink:
Of course it could also mean the adapter is just rubbish.
I have checked and rechecked the antenna cleaned the socket it is a push fit and tested with a multi-meter that the circuit is complete and all OK.
So it seems that the adapter is just rubbish as you said so have ordered a new up-to-date usb unit that is Linux compatible.
In that case, you probably did the right thing :wink:
