I have peppermint 3 on my dual boot (XP) Compaq V5000 (V5214ea to be precise) .
The WiFi applet indicates it is not working due to firmware problems. It’s never worked. I rarely use this laptop but I am trying to get some more use out of it. It is old but hardly used. Before I have just used my Mobile phone acting as a router linked up by cable to it.
Directions to upgrade the firmware would appreciated.
If this should be in another category please feel free to move it.
I was also wondering…should we not have a Mint/Peppermint category? As a lot of questions are about that distro’.
Bus 001 Device 003: ID 04e8:6864 Samsung Electronics Co., Ltd
OK first let’s try the reinstalling the firmware, and if that doesn’t work try the wl drivers … and if that doesn’t work you’ll have to describe the connection and issue a little better
OK. Tried all of the above without any difference. I booted into XP and noticed that the button that turns WiFi on and off was blue (on).
Re-booting into Peppermint showed that the Button was not blue (on) but unlit. Pressing the WiFi on off button mad no difference. So, it may be that Peppermint cannot recognize the on/off button and that the drivers are OK really.
What do you think?
Edit:
This may a resurrection too far anyway. I am finding it impossible to install software via software manager. The mouse jumps around the screen randomly. When I’m typing text it goes all over the place missing spaces and inserting text randomly. I have had to edit this post 5 times but…it doesn’t do this in XP?!
Odd, you’re the second person that seems to be having the skipping around cursor in Peppermint 3 (on this forum), yet nobody has reported it on the Peppermint forum ??
Can you post the output from:
rfkill list
and the make/model of your laptop
to kill the touchpad whilst typing … run:
syndaemon -i 1 &
This should kill the touchpad whilst you type with a 1 second delay between the last keystroke and the touchpad becoming active again.
Does that help ?
it won’t survive a reboot … but if it helps, we can automate it to run at bootup.
The ‘Firmware’ notice was displayed by hovering the mouse pointer over the connections applet.
The WiFi has never worked and TBH is now becoming a secondary issue behind the keyboard and mouse problems.
It seems that the WiFi button is behind the fact that I cannot make the hardware active by pressing the WiFi button. A reboot into XP shows the button to be active at startup and can be pressed off.
Output
E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem.
Which I did and nothing has changed.
On another note I am wondering if there is damage to the keyboard mouse pad. Plugging in a USB mouse and keyboared has just as good as confirmed it.
Don’t bust yourself over the WiFi Mark as at least tether it.
On the plus side…seeing how much trouble I have had recently trying to keep knackered old laptops survive my Wife has decided I can spend some of MY own money and get a new one! Jeez! Thanks love, as I looked at her iPad brick with D&G cover that can do virtually FA.
I will use this laptop as a workstation with USB mouse and keyboard.
Okey Dokey … have you tried a Peppermint 4 LiveUSB … maybe the later kernel would help … if it does, we can either update the Peppermint 3 kernel, or just install Peppermint 4.
The bios doesn’t support usb booting so I tried Peppermint 4 and Ubuntu on live cd, still no change.
Thanks for trying. There will have been a good reason why this old Compaq was replaced by me and has sat in the cupboard and it probably was a damaged keyboard mouse…can’t remember.
Now to look for a low cost laptop 14"-15" not to big. Didn’t like what I saw in PC World might give Dell a go.
