Quando eu ligo o computador e dou o boot o xscreensaver não inicia. Daí eu inicio ele via interface gráfica e eu recebo a seguinte mensagem:
Parece que o daemon do xscreensaver não está sendo executado no monitor “.0”. Lançá-lo agora?
Aí se eu respondo OK ele inicia e funciona normalmente até o próximo boot.
Como eu poderia corrigir isto?
Sorry, I didn’t find where to edit the post. So I translate it now to English:
When I turn on the computer and boot it, xscreensaver does not start. Then I start it via GUI and I get the following message:
It looks like the xscreensaver daemon is not running on monitor “.0”. Launch it now?
Then if I answer OK it starts and works properly until the next boot.
How could I fix this issue?
nogueira@nogueira-pendrive:~$ cat /proc/version
Linux version 5.0.0-31-generic (buildd@lgw01-amd64-046) (gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)) #33~18.04.1-Ubuntu SMP Tue Oct 1 10:20:39 UTC 2019
I installed Ubuntu LTS 18.04
Open a terminal and run:
gedit ~/.config/autostart/xscreensaver-autostart.desktop
when a blank file opens in the gedit text editor, make it read:
[Desktop Entry]
Type=Application
Name=Xscreensaver Autostart
Comment=Autostart the Xscreensaver Daemon
Exec=xscreensaver -nosplash
Icon=xscreensaver
Terminal=false
SAVE the file and exit the text efditor.
Log off/on (or reboot) ← IMPORTANT
Once you’ve logged back on, test the screensaver
Problem solved. It works now. Thanks a lot!
