Docky Docking (SOLVED)
Are you using a custom theme in docky ? … non on the themes I have, have that half height black bar behind the icons ?
And for christ sake, next time change the wallpaper, or at least gimme a warning :wink:
Sorry mate what can I say :slight_smile:
I only using the stock themes available in Docky I’ve tried each of them one at a time in panel mode, non panel mode, 3D background 2D background I’ve run out of options
Just as a test I installed Docky on my wifes PC also running PM4 and it’s doing exactly the same, however I have an installation of Linux Lite that I haven’t used in ages and I installed Docky on that and it works perfectly
OK, this is now OFFICIALLY weird … if nobody else is having this issue (and if they were it would have come up on the Peppermint forum), we have to try work out what YOUR PC’s have running on them that everyone else’s doesn’t
If you run:
ps aux > ~/ps_aux.txt
can you attach the ps_aux.txt file from your home folder to your next posting.
This is my PC I can’t get on Chloes at the moment but I’ll post it as soon as I can
root      1413  0.0  0.1  35512  3864 ?        Sl   21:41   0:00 /usr/lib/accountsservice/accounts-daemon
root      1428  0.0  0.0      0     0 ?        S    21:41   0:00 [kauditd]
root      1430  0.0  0.1  30284  3436 ?        Sl   21:41   0:00 /usr/sbin/console-kit-daemon --no-daemon
root      1555  0.0  0.1  28892  3928 ?        Sl   21:41   0:00 /usr/lib/upower/upowerd
root      1556  0.0  0.6  19680 14124 ?        Ss   21:41   0:00 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
root      1559  0.0  0.0   4664   876 tty1     Ss+  21:41   0:00 /sbin/getty -8 38400 tty1
root      1734  0.0  0.1  17204  3228 ?        Sl   21:41   0:00 lightdm --session-child 12 19
nobody    1735  0.0  0.0   6700  1416 ?        S    21:41   0:00 /usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/NetworkManager/dnsmasq.pid --listen-address=127.0.1.1 --conf-file=/var/run/NetworkManager/dnsmasq.conf --cache-size=0 --proxy-dnssec --enable-dbus=org.freedesktop.NetworkManager.dnsmasq --conf-dir=/etc/NetworkManager/dnsmasq.d
root      1806  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1810  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1812  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1814  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1818  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1819  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1822  0.0  0.0      0     0 ?        S    21:41   0:00 [cifsd]
root      1873  0.0  0.0  13304  1520 ?        Ss   21:41   0:00 nmbd -D
graeme    1929  0.0  0.3  71268  6736 ?        Ssl  21:41   0:00 /usr/bin/lxsession -s Peppermint -e LXDE
graeme    1975  0.0  0.0   3880   532 ?        S    21:41   0:00 dbus-launch --autolaunch=5152df44109757adb05f73df51d07348 --binary-syntax --close-stderr
graeme    1977  0.0  0.0   3280   408 ?        Ss   21:41   0:00 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
graeme    1978  0.0  0.0   4128   204 ?        Ss   21:41   0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
graeme    1981  0.0  0.0   3880   528 ?        S    21:41   0:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
graeme    1982  0.0  0.0   4344  1600 ?        Ss   21:41   0:00 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
graeme    1995  0.0  0.2  48908  4500 ?        SLl  21:41   0:00 /usr/bin/gnome-keyring-daemon --start --components=ssh
graeme    2013  0.0  0.1  28836  2848 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfsd
graeme    2017  0.0  0.1  44100  3380 ?        Sl   21:41   0:00 /usr/lib/gvfs//gvfsd-fuse -f /run/user/graeme/gvfs
graeme    2026  1.2  0.5  46184 10408 ?        S    21:41   0:26 xfwm4
graeme    2030  0.1  0.8 281996 17580 ?        Sl   21:41   0:02 lxpanel --profile Peppermint
graeme    2031  0.0  0.1   8896  2480 ?        S    21:41   0:00 xscreensaver -no-splash
graeme    2033  0.0  0.6 207640 14140 ?        Sl   21:41   0:00 pcmanfm --desktop --profile peppermint
graeme    2034  0.0  0.3  52304  6328 ?        Sl   21:41   0:00 /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
graeme    2042  2.1  2.7 408676 56108 ?        Sl   21:41   0:44 cairo-dock
graeme    2044  0.0  0.7 207680 14572 ?        Sl   21:41   0:00 update-notifier
graeme    2046  0.0  0.3  78520  7252 ?        Sl   21:41   0:00 zeitgeist-datahub
graeme    2048  0.0  0.1  45276  3672 ?        Sl   21:41   0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
graeme    2056  0.0  0.9 277800 19192 ?        Sl   21:41   0:00 nm-applet
graeme    2057  0.0  0.0   3280  1408 ?        S    21:41   0:00 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
graeme    2060  0.0  0.1  17180  3088 ?        Sl   21:41   0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
graeme    2065  0.0  0.7 207040 14516 ?        Sl   21:41   0:00 cryptkeeper
graeme    2073 13.0  0.6  48856 12616 ?        S    21:41   4:36 cairo-clock
graeme    2082  0.0  0.1  42984  3624 ?        Sl   21:41   0:00 /usr/bin/zeitgeist-daemon
graeme    2084  0.7  2.5 402956 52408 ?        Ssl  21:41   0:15 /home/graeme/.dropbox-dist/dropbox
graeme    2092  0.0  0.2  50296  4736 ?        Sl   21:41   0:00 /usr/lib/zeitgeist/zeitgeist-fts
graeme    2107  0.0  0.0   6556  1692 ?        S    21:41   0:00 xbindkeys
graeme    2110  0.0  0.2 101120  5652 ?        S<l  21:41   0:00 /usr/bin/pulseaudio --start --log-target=syslog
rtkit     2112  0.0  0.0  21368  1228 ?        SNl  21:41   0:00 /usr/lib/rtkit/rtkit-daemon
graeme    2117  0.0  0.1  10296  2592 ?        S    21:41   0:00 /usr/lib/i386-linux-gnu/gconf/gconfd-2
graeme    2118  0.0  0.2  61036  4340 ?        Ssl  21:41   0:00 xfce4-power-manager
graeme    2120  0.0  0.1  26552  3472 ?        Ssl  21:41   0:00 /usr/lib/i386-linux-gnu/menu-cache/menu-cached
graeme    2132  0.0  0.1   6348  2280 ?        S    21:41   0:00 /usr/lib/i386-linux-gnu/xfce4/xfconf/xfconfd
graeme    2134  0.0  0.2  31312  4932 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
root      2155  0.0  0.2  53444  5396 ?        Sl   21:41   0:01 /usr/lib/udisks2/udisksd --no-debug
ntp       2193  0.0  0.0   5724  1928 ?        Ss   21:41   0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:109
graeme    2197  0.0  0.1  28916  2936 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
graeme    2198  0.0  0.0   5484   288 ?        S    21:41   0:00 /bin/cat
graeme    2207  0.0  0.1  40228  2848 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
graeme    2213  0.0  0.1  27692  2484 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
graeme    2250  0.0  0.0   4688  1288 ?        Ss   21:41   0:00 /opt/teamviewer8/tv_bin/wine/bin/wineserver
root      2251  0.0  0.0      0     0 ?        S    21:41   0:00 [kworker/1:5]
graeme    2270  0.0  0.3  16136  6812 ?        S    21:41   0:00 python /usr/lib/i386-linux-gnu/cairo-dock/cairo-dock-launcher-API-daemon
graeme    2276  0.0  1.2 111320 26632 ?        Sl   21:41   0:01 /usr/bin/python /usr/lib/ubuntuone-client/ubuntuone-syncdaemon
graeme    2288  0.0  0.1  39984  4056 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.3 /org/gtk/gvfs/exec_spaw/0
graeme    2338  0.0  0.1  39864  3888 ?        Sl   21:41   0:00 /usr/lib/gvfs/gvfsd-computer --spawner :1.3 /org/gtk/gvfs/exec_spaw/1
graeme    2380  0.0  0.1  11672  2132 ?        S    21:41   0:00 /usr/bin/gnome-keyring-daemon --start --foreground --components=secrets
graeme    2389  2.4  5.7 670564 118260 ?       Sl   21:43   0:47 chromium-browser
graeme    2394  0.0  0.3 145560  6860 ?        S    21:43   0:00 chromium-browser
graeme    2395  0.0  0.0   2292   320 ?        S    21:43   0:00 /usr/lib/chromium-browser/chromium-browser-sandbox /usr/lib/chromium-browser/chromium-browser --type=zygote
graeme    2396  0.0  0.9 160460 19548 ?        S    21:43   0:00 chromium-browser --type=zygote
graeme    2400  0.0  0.2 168656  5484 ?        S    21:43   0:00 chromium-browser --type=zygote
graeme    2446  0.0  1.3 217184 26948 ?        Sl   21:43   0:00 /usr/lib/chromium-browser/chro
graeme    2455  0.0  1.2 217480 26048 ?        Sl   21:43   0:00 /usr/lib/chromium-browser/chro
graeme    2460  0.0  1.2 217480 26044 ?        Sl   21:43   0:00 /usr/lib/chromium-browser/chro
graeme    2466  0.0  1.7 229508 36064 ?        Sl   21:43   0:01 /usr/lib/chromium-browser/chro
graeme    2498  0.7  2.7 240020 55812 ?        Sl   21:44   0:14 /usr/lib/chromium-browser/chro
root      2800  0.0  0.0      0     0 ?        S    21:55   0:00 [kworker/1:0]
graeme    2807  3.6  3.4 256116 70736 ?        Sl   21:55   0:46 /usr/lib/chromium-browser/chro
root      2880  0.0  0.0      0     0 ?        S    21:58   0:00 [kworker/u:1]
root      2891  0.0  0.0      0     0 ?        S    22:00   0:00 [kworker/1:4]
root      2935  0.0  0.0      0     0 ?        S    22:03   0:00 [kworker/u:0]
graeme    2936  1.7  3.3 249064 68804 ?        Sl   22:04   0:12 /usr/lib/chromium-browser/chro
graeme    3014  1.7  2.2 231016 46728 ?        Sl   22:08   0:08 chromium-browser --type=plugin --plugin-path=/usr/lib/flashplugin-installer/libflashplayer.so --lang=en-GB --channel=2389.20.39231
root      3023  0.0  0.0      0     0 ?        S    22:09   0:00 [kworker/1:6]
root      3083  0.0  0.0      0     0 ?        S    22:13   0:00 [kworker/u:2]
root      3084  0.0  0.0      0     0 ?        S    22:14   0:00 [kworker/1:7]
graeme    3099  9.3  0.8 209556 17168 ?        Sl   22:16   0:00 lxterminal
graeme    3100  0.0  0.0   2436   720 ?        S    22:16   0:00 gnome-pty-helper
graeme    3101  1.4  0.1   7424  2560 pts/0    Ss   22:16   0:00 /bin/bash
Chloes PC
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.0  0.1   3904  2112 ?        Ss   Oct06   0:02 /sbin/init
root         2  0.0  0.0      0     0 ?        S    Oct06   0:00 [kthreadd]
root         3  0.0  0.0      0     0 ?        S    Oct06   0:14 [ksoftirqd/0]
root         5  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kworker/0:0H]
root         7  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kworker/u:0H]
root         8  0.0  0.0      0     0 ?        S    Oct06   0:00 [migration/0]
root         9  0.0  0.0      0     0 ?        S    Oct06   0:00 [rcu_bh]
root        10  0.0  0.0      0     0 ?        S    Oct06   0:17 [rcu_sched]
root        11  0.0  0.0      0     0 ?        S    Oct06   0:00 [watchdog/0]
root        12  0.0  0.0      0     0 ?        S<   Oct06   0:00 [cpuset]
root        13  0.0  0.0      0     0 ?        S<   Oct06   0:00 [khelper]
root        14  0.0  0.0      0     0 ?        S    Oct06   0:00 [kdevtmpfs]
root        15  0.0  0.0      0     0 ?        S<   Oct06   0:00 [netns]
root        16  0.0  0.0      0     0 ?        S    Oct06   0:00 [bdi-default]
root        17  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kintegrityd]
root        18  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kblockd]
root        19  0.0  0.0      0     0 ?        S<   Oct06   0:00 [ata_sff]
root        20  0.0  0.0      0     0 ?        S    Oct06   0:00 [khubd]
root        21  0.0  0.0      0     0 ?        S<   Oct06   0:00 [md]
root        22  0.0  0.0      0     0 ?        S<   Oct06   0:00 [devfreq_wq]
root        24  0.0  0.0      0     0 ?        S    Oct06   0:00 [khungtaskd]
root        25  0.0  0.0      0     0 ?        S    Oct06   0:00 [kswapd0]
root        26  0.0  0.0      0     0 ?        SN   Oct06   0:00 [ksmd]
root        27  0.0  0.0      0     0 ?        SN   Oct06   0:00 [khugepaged]
root        28  0.0  0.0      0     0 ?        S    Oct06   0:00 [fsnotify_mark]
root        29  0.0  0.0      0     0 ?        S    Oct06   0:00 [ecryptfs-kthrea]
root        30  0.0  0.0      0     0 ?        S<   Oct06   0:00 [crypto]
root        41  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kthrotld]
root        43  0.0  0.0      0     0 ?        S    Oct06   0:00 [scsi_eh_0]
root        44  0.0  0.0      0     0 ?        S    Oct06   0:00 [scsi_eh_1]
root        47  0.0  0.0      0     0 ?        S    Oct06   0:11 [kworker/0:2]
root        48  0.0  0.0      0     0 ?        S<   Oct06   0:00 [binder]
root        67  0.0  0.0      0     0 ?        S<   Oct06   0:00 [deferwq]
root        68  0.0  0.0      0     0 ?        S<   Oct06   0:00 [charger_manager]
root        69  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kworker/0:1H]
root       229  0.0  0.0      0     0 ?        S    Oct06   0:01 [jbd2/sda1-8]
root       230  0.0  0.0      0     0 ?        S<   Oct06   0:00 [ext4-dio-unwrit]
root       252  0.0  0.0      0     0 ?        S    Oct06   0:00 [flush-8:0]
root       315  0.0  0.0   2888   552 ?        S    Oct06   0:00 upstart-file-bridge --daemon
chloe      321  0.0  0.0   6472  1144 pts/0    R+   22:29   0:00 ps aux
root       330  0.0  0.0   2892   608 ?        S    Oct06   0:00 upstart-udev-bridge --daemon
root       340  0.0  0.0   3164  1428 ?        Ss   Oct06   0:00 /sbin/udevd --daemon
root       493  0.0  0.0      0     0 ?        S<   Oct06   0:00 [cifsiod]
chloe      510  0.0  0.2  20516  3600 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfsd-metadata
102        568  0.0  0.1   3736  1640 ?        Ss   Oct06   0:08 dbus-daemon --system --fork
root       598  0.0  0.0   3160  1028 ?        S    Oct06   0:00 /sbin/udevd --daemon
root       599  0.0  0.0   3160   916 ?        S    Oct06   0:00 /sbin/udevd --daemon
root       627  0.0  0.1   4844  1628 ?        Ss   Oct06   0:00 /usr/sbin/bluetoothd
syslog     630  0.0  0.0  30220  1424 ?        Sl   Oct06   0:08 rsyslogd -c5
root       660  0.0  0.2   7792  3164 ?        Ss   Oct06   0:00 /usr/sbin/cupsd -F
root       664  0.0  0.0      0     0 ?        S<   Oct06   0:00 [krfcommd]
root       675  0.0  0.0      0     0 ?        S<   Oct06   0:00 [kpsmoused]
root       688  0.0  0.0      0     0 ?        S<   Oct06   0:00 [cfg80211]
root       701  0.0  0.0      0     0 ?        S<   Oct06   0:00 [ttm_swap]
root       793  0.0  0.3  23208  4656 ?        Ss   Oct06   0:00 smbd -F
root       817  0.0  0.1   7512  2884 ?        Ss   Oct06   0:00 /usr/sbin/modem-manager
root       823  0.0  0.0  23724  1268 ?        S    Oct06   0:00 smbd -F
root       857  0.0  0.3  44384  6096 ?        Ssl  Oct06   0:19 NetworkManager
root       863  0.0  0.3  30624  4736 ?        Sl   Oct06   0:01 /usr/lib/policykit-1/polkitd --no-debug
root       904  0.0  0.1   6276  2220 ?        Ss   Oct06   0:04 /sbin/wpa_supplicant -B -P /run/sendsigs.omit.d/wpasupplicant.pid -u -s -O /var/run/wpa_supplicant
root       935  0.0  0.0   3008   716 ?        S    Oct06   0:00 upstart-socket-bridge --daemon
root       985  0.0  0.1   5532  3088 ?        S    Oct06   0:00 /sbin/dhclient -d -sf /usr/lib/NetworkManager/nm-dhcp-client.action -pf /run/sendsigs.omit.d/network-manager.dhclient-wlan2.pid -lf /var/lib/NetworkManager/dhclient-b39511b7-dfe4-4e68-a9a5-2574701b86a2-wlan2.lease -cf /var/lib/NetworkManager/dhclient-wlan2.conf wlan2
root      1125  0.0  0.0   4664   856 tty4     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty4
root      1130  0.0  0.0   4664   864 tty5     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty5
root      1146  0.0  0.0   4664   860 tty2     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty2
root      1148  0.0  0.0   4664   864 tty3     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty3
root      1154  0.0  0.0   4664   864 tty6     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty6
root      1176  0.0  0.0   2212   612 ?        Ss   Oct06   0:00 acpid -c /etc/acpi/events -s /var/run/acpid.socket
root      1181  0.0  0.0   2780   896 ?        Ss   Oct06   0:00 cron
root      1191  0.0  0.1  33816  2960 ?        Ssl  Oct06   0:00 lightdm
root      1222  0.1  0.1   5048  2216 ?        SNs  Oct06   2:14 /usr/sbin/preload -s /var/lib/preload/preload.state
root      1226  1.5  4.2 140004 65604 tty7     Ss+  Oct06  24:06 /usr/bin/X :0 -core -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch -background none
timidity  1275  0.0  0.4  17924  6684 ?        S    Oct06   0:00 /usr/bin/timidity -Os -iAD
nobody    1815  0.0  0.0   6700  1384 ?        S    Oct06   0:00 /usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/NetworkManager/dnsmasq.pid --listen-address=127.0.1.1 --conf-file=/var/run/NetworkManager/dnsmasq.conf --cache-size=0 --proxy-dnssec --enable-dbus=org.freedesktop.NetworkManager.dnsmasq --conf-dir=/etc/NetworkManager/dnsmasq.d
root      1935  0.0  0.1  13304  1776 ?        Ss   Oct06   0:01 nmbd -D
root      1961  0.0  0.0      0     0 ?        S    Oct06   0:01 [cifsd]
root      1969  0.0  0.2  17176  3116 ?        Sl   Oct06   0:00 lightdm --session-child 12 15
root      1978  0.0  0.0      0     0 ?        S    Oct06   0:00 [kauditd]
root      1983  0.0  0.2  34488  3780 ?        Sl   Oct06   0:01 /usr/lib/accountsservice/accounts-daemon
root      2014  0.0  0.2  29260  3416 ?        Sl   Oct06   0:00 /usr/sbin/console-kit-daemon --no-daemon
chloe     2088  0.0  0.4  70812  7124 ?        Ssl  Oct06   0:01 /usr/bin/lxsession -s Peppermint -e LXDE
chloe     2132  0.0  0.0   4128   208 ?        Ss   Oct06   0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
chloe     2135  0.0  0.0   3880   512 ?        S    Oct06   0:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
chloe     2136  0.0  0.1   4332  1616 ?        Ss   Oct06   0:01 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
chloe     2149  0.0  0.2  48784  4032 ?        Sl   Oct06   0:00 /usr/bin/gnome-keyring-daemon --start --components=ssh
chloe     2157  0.0  0.1  28832  2848 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfsd
chloe     2161  0.0  0.2  43076  3368 ?        Sl   Oct06   0:00 /usr/lib/gvfs//gvfsd-fuse -f /run/user/chloe/gvfs
chloe     2164  0.0  0.7  47208 11452 ?        S    Oct06   0:41 xfwm4
chloe     2168  0.0  1.2 179860 19472 ?        Sl   Oct06   0:34 lxpanel --profile Peppermint
chloe     2171  0.0  0.1   8860  2284 ?        S    Oct06   0:04 xscreensaver -no-splash
chloe     2176  0.0  2.0 158176 31148 ?        Sl   Oct06   0:45 pcmanfm --desktop --profile peppermint
chloe     2177  0.0  1.0  85436 15824 ?        Sl   Oct06   0:01 /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
chloe     2185  0.0  1.0 101188 15484 ?        Sl   Oct06   0:07 update-notifier
chloe     2187  0.0  0.4  76944  6496 ?        Sl   Oct06   0:02 zeitgeist-datahub
root      2190  0.0  0.9  19680 14076 ?        Ss   Oct06   0:03 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
chloe     2193  0.0  1.2 118248 19732 ?        Sl   Oct06   0:12 nm-applet
root      2196  0.0  0.0   4664   868 tty1     Ss+  Oct06   0:00 /sbin/getty -8 38400 tty1
chloe     2211  0.0  0.1   6556  1628 ?        S    Oct06   0:00 xbindkeys
chloe     2217  0.0  0.3  44244  4956 ?        Sl   Oct06   0:00 /usr/bin/zeitgeist-daemon
chloe     2224  0.0  0.5  51940  7968 ?        Sl   Oct06   0:00 /usr/lib/zeitgeist/zeitgeist-fts
chloe     2227  0.0  0.2  44196  3704 ?        Sl   Oct06   0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
chloe     2229  0.0  0.3 101020  5404 ?        S<l  Oct06   0:05 /usr/bin/pulseaudio --start --log-target=syslog
rtkit     2232  0.0  0.0  21368  1208 ?        SNl  Oct06   0:00 /usr/lib/rtkit/rtkit-daemon
chloe     2235  0.0  0.3  61904  5468 ?        Ssl  Oct06   0:00 xfce4-power-manager
chloe     2244  0.0  0.0   5484   288 ?        S    Oct06   0:00 /bin/cat
chloe     2249  0.0  0.0   3280  1368 ?        S    Oct06   0:00 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
chloe     2252  0.0  0.2  26552  3528 ?        Ssl  Oct06   0:00 /usr/lib/i386-linux-gnu/menu-cache/menu-cached
chloe     2260  0.0  0.1  17180  3036 ?        Sl   Oct06   0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
chloe     2263  0.0  0.2  31304  4488 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
root      2266  0.0  0.3  52212  4776 ?        Sl   Oct06   0:00 /usr/lib/udisks2/udisksd --no-debug
chloe     2273  0.0  0.1   6348  2276 ?        S    Oct06   0:00 /usr/lib/i386-linux-gnu/xfce4/xfconf/xfconfd
root      2278  0.0  0.2  28896  3812 ?        Sl   Oct06   0:00 /usr/lib/upower/upowerd
chloe     2309  0.0  0.1  27692  2648 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
chloe     2320  0.0  0.1  39204  2796 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
chloe     2344  0.0  0.1  28788  2836 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
ntp       2467  0.0  0.1   5724  1864 ?        Ss   Oct06   0:11 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:109
chloe     2472  0.0  0.1  10272  2524 ?        S    Oct06   0:00 /usr/lib/i386-linux-gnu/gconf/gconfd-2
chloe     2486  0.0  0.3 162568  4928 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.3 /org/gtk/gvfs/exec_spaw/0
chloe    23871  0.0  0.4  16100  6776 ?        S    Oct06   0:00 python /usr/lib/i386-linux-gnu/cairo-dock/cairo-dock-launcher-API-daemon
chloe    23883  0.0  0.2  55232  3868 ?        Sl   Oct06   0:00 /usr/lib/gvfs/gvfsd-computer --spawner :1.3 /org/gtk/gvfs/exec_spaw/1
chloe    28781  0.0  0.1  24212  2348 ?        Sl   19:24   0:00 /usr/lib/dconf/dconf-service
chloe    30931  0.0  0.2  42392  4376 ?        Sl   20:32   0:00 /usr/lib/gvfs/gvfsd-http --spawner :1.3 /org/gtk/gvfs/exec_spaw/2
chloe    31224  0.7  3.0 143732 46660 ?        Sl   20:40   0:49 mono --debug /usr/lib/docky/Docky.exe --debug
chloe    31674  0.4  5.5 504188 85796 ?        Sl   20:59   0:26 chromium-browser --ppapi-flash-path=/opt/google/chromium/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.8.800.170
chloe    31680  0.0  0.4 145404  6628 ?        S    20:59   0:00 chromium-browser --ppapi-flash-path=/opt/google/chromium/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.8.800.170
chloe    31681  0.0  0.0   2292   320 ?        S    20:59   0:00 /usr/lib/chromium-browser/chromium-browser-sandbox /usr/lib/chromium-browser/chromium-browser --type=zygote --ppapi-flash-path=/opt/google/chromium/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.8.800.170
chloe    31682  0.0  1.4 173376 21812 ?        S    20:59   0:00 chromium-browser --type=zygote --ppapi-flash-path=/opt/google/chromium/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.8.800.170
chloe    31686  0.0  0.3 181572  5788 ?        S    20:59   0:00 chromium-browser --type=zygote --ppapi-flash-path=/opt/google/chromium/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.8.800.170
chloe    31742  0.4  5.4 280720 84044 ?        Sl   20:59   0:23 /usr/lib/chromium-browser/chromium-browser --type=renderer --lang=en-GB --force-fieldtrials=ForceCompositingMode/disable/InfiniteCache/No/
root     32656  0.0  0.0      0     0 ?        S    22:16   0:00 [kworker/u:1]
root     32686  0.0  0.0      0     0 ?        S    22:19   0:00 [kworker/0:0]
root     32687  0.0  0.0      0     0 ?        S    22:22   0:00 [kworker/u:0]
root     32713  0.0  0.0      0     0 ?        S    22:24   0:00 [kworker/0:1]
root     32714  0.0  0.0      0     0 ?        S    22:28   0:00 [kworker/u:2]
chloe    32742 12.0  1.0  87600 15816 ?        Sl   22:29   0:00 lxterminal
chloe    32743  0.0  0.0   2436   708 ?        S    22:29   0:00 gnome-pty-helper
chloe    32744  1.8  0.1   7372  2428 pts/0    Ss   22:29   0:00 /bin/bash
Pats PC
root         1  0.0  0.0   3896  1860 ?        Ss   Sep27   0:03 /sbin/init
root         2  0.0  0.0      0     0 ?        S    Sep27   0:00 [kthreadd]
root         3  0.0  0.0      0     0 ?        S    Sep27   1:55 [ksoftirqd/0]
root         5  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kworker/0:0H]
root         7  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kworker/u:0H]
root         8  0.0  0.0      0     0 ?        S    Sep27   0:00 [migration/0]
root         9  0.0  0.0      0     0 ?        S    Sep27   0:00 [rcu_bh]
root        10  0.0  0.0      0     0 ?        S    Sep27   1:16 [rcu_sched]
root        11  0.0  0.0      0     0 ?        S    Sep27   0:05 [watchdog/0]
root        12  0.0  0.0      0     0 ?        S<   Sep27   0:00 [cpuset]
root        13  0.0  0.0      0     0 ?        S<   Sep27   0:00 [khelper]
root        14  0.0  0.0      0     0 ?        S    Sep27   0:00 [kdevtmpfs]
root        15  0.0  0.0      0     0 ?        S<   Sep27   0:00 [netns]
root        16  0.0  0.0      0     0 ?        S    Sep27   0:00 [bdi-default]
root        17  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kintegrityd]
root        18  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kblockd]
root        19  0.0  0.0      0     0 ?        S<   Sep27   0:00 [ata_sff]
root        20  0.0  0.0      0     0 ?        S    Sep27   0:00 [khubd]
root        21  0.0  0.0      0     0 ?        S<   Sep27   0:00 [md]
root        22  0.0  0.0      0     0 ?        S<   Sep27   0:00 [devfreq_wq]
root        24  0.0  0.0      0     0 ?        S    Sep27   0:00 [khungtaskd]
root        25  0.0  0.0      0     0 ?        S    Sep27   0:17 [kswapd0]
root        26  0.0  0.0      0     0 ?        SN   Sep27   0:00 [ksmd]
root        27  0.0  0.0      0     0 ?        SN   Sep27   0:00 [khugepaged]
root        28  0.0  0.0      0     0 ?        S    Sep27   0:00 [fsnotify_mark]
root        29  0.0  0.0      0     0 ?        S    Sep27   0:00 [ecryptfs-kthrea]
root        30  0.0  0.0      0     0 ?        S<   Sep27   0:00 [crypto]
root        41  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kthrotld]
root        43  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_0]
root        44  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_1]
root        47  0.0  0.0      0     0 ?        S<   Sep27   0:00 [binder]
root        66  0.0  0.0      0     0 ?        S<   Sep27   0:00 [deferwq]
root        67  0.0  0.0      0     0 ?        S<   Sep27   0:00 [charger_manager]
root        71  0.0  0.0      0     0 ?        S<   Sep27   0:46 [kworker/0:1H]
root       206  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_2]
root       207  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_3]
root       216  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_4]
root       217  0.0  0.0      0     0 ?        S    Sep27   2:06 [usb-storage]
root       225  0.0  0.0      0     0 ?        S    Sep27   0:00 [scsi_eh_5]
root       226  0.0  0.0      0     0 ?        S    Sep27   0:14 [usb-storage]
root       246  0.0  0.0      0     0 ?        S    Sep27   0:35 [jbd2/sdb6-8]
root       247  0.0  0.0      0     0 ?        S<   Sep27   0:00 [ext4-dio-unwrit]
root       294  0.0  0.0   2888   384 ?        S    Sep27   0:00 upstart-file-bridge --daemon
root       345  0.0  0.0   2892   564 ?        S    Sep27   0:00 upstart-udev-bridge --daemon
root       347  0.0  0.0   3192  1184 ?        Ss   Sep27   0:00 /sbin/udevd --daemon
root       618  0.0  0.0      0     0 ?        S<   Sep27   0:00 [kpsmoused]
root       663  0.0  0.0      0     0 ?        S<   Sep27   0:00 [cifsiod]
root       736  0.0  0.0      0     0 ?        S<   Sep27   0:00 [cfg80211]
syslog     779  0.0  0.0  30340  1124 ?        Sl   Sep27   1:18 rsyslogd -c5
root       834  0.0  0.0   2876   388 ?        S    Sep27   0:00 upstart-socket-bridge --daemon
102        861  0.0  0.0   3788  1528 ?        Ss   Sep27   0:40 dbus-daemon --system --fork
root       888  0.0  0.0   7512  1780 ?        Ss   Sep27   0:00 /usr/sbin/modem-manager
root       924  0.0  0.1   7856  2400 ?        Ss   Sep27   0:02 /usr/sbin/cupsd -F
root       925  0.0  0.0   4844  1004 ?        Ss   Sep27   0:00 /usr/sbin/bluetoothd
root       941  0.0  0.0      0     0 ?        S<   Sep27   0:00 [krfcommd]
root       981  0.0  0.1  44380  3604 ?        Ssl  Sep27   1:30 NetworkManager
root       989  0.0  0.0  23216  1772 ?        Ss   Sep27   0:00 smbd -F
root       995  0.0  0.1  30660  3688 ?        Sl   Sep27   0:04 /usr/lib/policykit-1/polkitd --no-debug
root      1057  0.0  0.0  23732  1204 ?        S    Sep27   0:01 smbd -F
root      1092  0.0  0.0   6276  1512 ?        Ss   Sep27   0:14 /sbin/wpa_supplicant -B -P /run/sendsigs.omit.d/wpasupplicant.pid -u -s -O /var/run/wpa_supplicant
root      1161  0.0  0.0   4664   544 tty4     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty4
root      1165  0.0  0.0   4664   540 tty5     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty5
root      1184  0.0  0.0   4664   548 tty2     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty2
root      1186  0.0  0.0   4664   548 tty3     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty3
root      1193  0.0  0.0   4664   540 tty6     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty6
root      1201  0.0  0.1  45572  2488 ?        Ssl  Sep27   1:45 /opt/teamviewer8/tv_bin/teamviewerd -f
root      1212  0.0  0.0   2212   468 ?        Ss   Sep27   0:00 acpid -c /etc/acpi/events -s /var/run/acpid.socket
root      1213  0.0  0.0  33848  1820 ?        SLsl Sep27   0:00 lightdm
root      1214  0.0  0.0   2780   640 ?        Ss   Sep27   0:01 cron
root      1261  4.1  4.1 181008 84056 tty7     Ss+  Sep27 633:29 /usr/bin/X :0 -core -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch -background none
root      1262  0.0  0.0   4912  1840 ?        SNs  Sep27   6:59 /usr/sbin/preload -s /var/lib/preload/preload.state
nobody    1278  0.0  0.0   6700   932 ?        S    Sep27   0:05 /usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/NetworkManager/dnsmasq.pid --listen-address=127.0.1.1 --conf-file=/var/run/NetworkManager/dnsmasq.conf --cache-size=0 --proxy-dnssec --enable-dbus=org.freedesktop.NetworkManager.dnsmasq --conf-dir=/etc/NetworkManager/dnsmasq.d
root      1302  0.0  0.0   4664   544 tty1     Ss+  Sep27   0:00 /sbin/getty -8 38400 tty1
root      1397  0.0  0.0      0     0 ?        S    22:06   0:00 [kworker/0:1]
root      1415  0.0  0.0  13312  1444 ?        Ss   Sep27   0:11 nmbd -D
root      1454  0.0  0.0      0     0 ?        S    22:14   0:00 [kworker/0:3]
root      1472  0.0  0.0      0     0 ?        S    22:18   0:00 [kworker/u:0]
root      1492  0.0  0.0      0     0 ?        S    22:23   0:00 [kworker/0:4]
root      1504  0.0  0.0      0     0 ?        S    22:24   0:00 [kworker/u:1]
root      1569  0.0  0.0      0     0 ?        S    Sep27   0:06 [cifsd]
root      1570  0.0  0.0      0     0 ?        S    Sep27   0:06 [cifsd]
root      1695  0.0  0.0      0     0 ?        S    Sep27   0:06 [cifsd]
root      1696  0.0  0.0      0     0 ?        S    Sep27   0:06 [cifsd]
root      1697  0.0  0.0      0     0 ?        S    Sep27   0:06 [cifsd]
root      1796  0.0  0.0      0     0 ?        S    22:30   0:00 [kworker/u:2]
root      1818  0.0  0.0      0     0 ?        S    Sep27   0:07 [cifsd]
pat       1822 12.8  5.8 582800 119784 ?       Sl   22:31   0:09 chromium-browser
pat       1826  0.2  0.3 145348  6548 ?        S    22:31   0:00 chromium-browser
pat       1827  0.0  0.0   2292   320 ?        S    22:31   0:00 /usr/lib/chromium-browser/chromium-browser-sandbox /usr/lib/chromium-browser/chromium-browser --type=zygote
pat       1828  0.3  0.9 158808 19400 ?        S    22:31   0:00 chromium-browser --type=zygote
pat       1832  0.0  0.2 167004  5208 ?        S    22:31   0:00 chromium-browser --type=zygote
root      1853  0.0  0.0      0     0 ?        S    Sep27   0:07 [cifsd]
pat       1879  0.4  1.3 215344 26700 ?        Sl   22:31   0:00 /usr/lib/chromium-browser/chro
pat       1888  2.1  1.7 277572 34584 ?        Sl   22:31   0:01 /usr/lib/chromium-browser/chro
pat       1918 13.2  3.2 243824 66032 ?        Sl   22:31   0:06 /usr/lib/chromium-browser/chro
root      1934  0.0  0.0      0     0 ?        S    22:31   0:00 [kworker/0:2]
pat       1940  5.7  0.7 163460 14800 ?        Sl   22:32   0:00 lxterminal
pat       1941  0.0  0.0   2436   708 ?        S    22:32   0:00 gnome-pty-helper
pat       1942  1.2  0.1   7436  2512 pts/1    Ss   22:32   0:00 /bin/bash
pat       1944  0.0  0.1  55400  2532 ?        Sl   Sep30   0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.3 /org/gtk/gvfs/exec_spaw/1
pat       1951  0.0  0.1 104544  2828 ?        Sl   Sep30   0:00 /usr/lib/gvfs/gvfsd-computer --spawner :1.3 /org/gtk/gvfs/exec_spaw/2
pat       1992  0.0  0.0   6472  1160 pts/1    R+   22:32   0:00 ps aux
root      2108  0.0  0.0  34492  1976 ?        Sl   Sep27   0:12 /usr/lib/accountsservice/accounts-daemon
root      2123  0.0  0.0      0     0 ?        S    Sep27   0:00 [kauditd]
root      2125  0.0  0.1  29272  2480 ?        Sl   Sep27   0:01 /usr/sbin/console-kit-daemon --no-daemon
root      2228  0.0  0.1  28892  2296 ?        Sl   Sep27   0:00 /usr/lib/upower/upowerd
root      2391  0.0  0.0  17204  1832 ?        Sl   Sep27   0:00 lightdm --session-child 12 19
ntp       2418  0.0  0.0   5724  1264 ?        Ss   Sep27   0:52 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:109
pat       9341  0.0  0.0  24212  1440 ?        Sl   Sep28   0:00 /usr/lib/dconf/dconf-service
pat       9748  0.0  2.6 208284 54836 ?        SNl  07:40   0:08 /usr/bin/python3 /usr/bin/update-manager --no-update --no-focus-on-map
pat      12570  0.0  0.1  70084  3336 ?        Ssl  Sep27   0:02 /usr/bin/lxsession -s Peppermint -e LXDE
pat      13179  0.0  0.0   4128   208 ?        Ss   Sep27   0:02 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
pat      13182  0.0  0.0   3880   340 ?        S    Sep27   0:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch /usr/bin/startpeppermint
pat      13183  0.0  0.0   4388  1520 ?        Ss   Sep27   0:05 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
pat      13196  0.0  0.0  48784  1868 ?        Sl   Sep27   0:00 /usr/bin/gnome-keyring-daemon --start --components=ssh
pat      13204  0.0  0.0  28832  1832 ?        Sl   Sep27   0:00 /usr/lib/gvfs/gvfsd
pat      13208  0.0  0.0  43076  1380 ?        Sl   Sep27   0:00 /usr/lib/gvfs//gvfsd-fuse -f /run/user/pat/gvfs
pat      13216  0.7  0.3  46220  7300 ?        S    Sep27 106:05 xfwm4
pat      13218  0.0  0.5 172820 12180 ?        Sl   Sep27   2:27 lxpanel --profile Peppermint
pat      13219  0.0  0.0   8864  1380 ?        S    Sep27   0:16 xscreensaver -no-splash
pat      13224  0.0  0.9 190660 19276 ?        Sl   Sep27   0:27 pcmanfm --desktop --profile peppermint
pat      13229  0.0  0.6 160548 13380 ?        Sl   Sep27   0:00 /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
pat      13244  0.0  0.0  44168  1840 ?        Sl   Sep27   0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
pat      13248  0.0  0.1  61028  3260 ?        Ssl  Sep27   0:01 xfce4-power-manager
pat      13249  0.0  0.0   3280   984 ?        S    Sep27   0:00 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
pat      13255  0.0  0.0  17180  1816 ?        Sl   Sep27   0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
pat      13259  0.0  0.0   6348  1468 ?        S    Sep27   0:00 /usr/lib/i386-linux-gnu/xfce4/xfconf/xfconfd
pat      13261  0.0  0.0   6556  1484 ?        S    Sep27   0:00 xbindkeys
pat      13265  0.0  0.1  26552  2372 ?        Ssl  Sep27   0:00 /usr/lib/i386-linux-gnu/menu-cache/menu-cached
pat      13268  0.0  0.4 176324  9188 ?        Sl   Sep27   0:33 update-notifier
pat      13272  0.0  0.2  40012  4632 ?        Sl   Sep27   0:13 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
root     13275  0.0  0.2  60748  4584 ?        Sl   Sep27   7:36 /usr/lib/udisks2/udisksd --no-debug
pat      13282  0.0  0.1  85240  3948 ?        Sl   Sep27   0:16 zeitgeist-datahub
pat      13288  0.0  0.1  44116  3148 ?        Sl   Sep27   0:00 /usr/bin/zeitgeist-daemon
pat      13291  0.0  0.4 229328 10012 ?        Sl   Sep27   0:54 nm-applet
pat      13303  0.0  0.0  28788  1904 ?        Sl   Sep27   0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
pat      13307  0.0  0.0  39204  1692 ?        Sl   Sep27   0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
pat      13312  0.0  0.0  27692  1820 ?        Sl   Sep27   0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
pat      13333  0.0  0.1  51928  3652 ?        Sl   Sep27   0:01 /usr/lib/zeitgeist/zeitgeist-fts
pat      13334  0.0  0.0  10280  2032 ?        S    Sep27   0:01 /usr/lib/i386-linux-gnu/gconf/gconfd-2
pat      13341  0.0  0.0   5484    56 ?        S    Sep27   0:00 /bin/cat
pat      13344  0.6  8.0 497216 164156 ?       Ssl  Sep27  93:53 /home/pat/.dropbox-dist/dropbox
pat      13365  0.0  0.0   4688  1008 ?        Ss   Sep27   0:01 /opt/teamviewer8/tv_bin/wine/bin/wineserver
pat      13739  7.2  0.3  48080  7232 ?        S    Sep27 1098:24 cairo-clock
lp       28330  0.0  0.0   2496   544 ?        Ss   Oct06   0:00 /usr/sbin/lpd -s
pat      28857  0.0  0.1  42392  2232 ?        Sl   Sep27   0:00 /usr/lib/gvfs/gvfsd-http --spawner :1.3 /org/gtk/gvfs/exec_spaw/0
root     29224  0.0  0.0      0     0 ?        S    18:55   0:00 [flush-8:16]
pat      29786  0.0  0.0  20660  2032 ?        Sl   Sep30   0:00 /usr/lib/gvfs/gvfsd-metadata
root     30159  0.0  0.0   3188  1080 ?        S    Oct06   0:00 /sbin/udevd --daemon
root     30160  0.0  0.0   3188   820 ?        S    Oct06   0:00 /sbin/udevd --daemon
root     30488  0.0  0.0      0     0 ?        S    20:49   0:00 [kworker/0:0]
OK, I can’t spot anything in those that’s common to all 3 and missing in mine :o
That said, the only one that was running docky at the time was Chloe’s … and for some reason that seemed to be running docky in debug mode.
can you post the output from:
for APT in `find /etc/apt/ -name *.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
OK, let’s try Plank instead of Docky … Plank is by the same people as Docky, but gets rid of the dependence on mono (so it’s a true Linux app) and gconf … it stores its shortcuts as plain text files so if you need to edit them manually it’s MUCH easier, and is lighter than Docky.
Apparently (or so I read) Docky3 if it ever happens (and it may not) will use the Plank underlying code (vala) rather than mono.
As yet it’s missing a couple of the features of Docky … such as a GUI settings panel (has to be done through a text file), and the icons don’t GROW as you mouse-over them.
It does however work better than Docky where no compositor is present … though you loose access to the themes without a compositor.
http://helpdeskgeek.com/linux-tips/plank-a-lightweight-application-dock-for-linux/
homepage:
http://wiki.go-docky.com/?title=Plank:Introduction
Anywho … to install Plank (don’t be thrown by the PPA name … as I said it’s by the same people as Docky):
sudo add-apt-repository ppa:ricotz/docky
sudo apt-get install plank
sudo apt-get upgrade
Now make sure Docky isn’t running, and fire up Plank from the menu (menu > Accessories > Plank)
If it works properly … uninstall Docky with:
sudo apt-get remove --purge docky
sudo apt-get autoremove
then a little cleaning up if you wish:
rm -v ~/.config/autostart/docky.desktop
rm -rv ~/.gconf/apps/docky-2
rm -rv ~/.cache/docky
To make Plank autostart:
cp -v /usr/share/applications/plank.desktop ~/.config/autostart/
REMEMBER … drag the SSB shortcuts from ~/.local/share/applications to Plank :wink:
Planks config file (for tweaking themes, screen position, etc.) is at:
gedit ~/.config/plank/dock1/stettings
it’s all pretty self-explanatory, but gimme a shout if you have any questions.
And before you ask … YES it is possible to remove the “Plank” icon from the dock … ask if you wanna know how :wink:
Thanks for that but unfortunately Plank doesn’t work either as it won’t make space when I drag an icon onto it preventing me from dropping the icon in.
I’ve tried it from the desktop, ~/.local/share/applications & /usr/share/applications and I see nothing wrong in the config file preventing drag & drop
You must shudder when I post a problem :slight_smile:
Plank doesn’t spread the icons during a drag/drop like Docky … you just drop them anywhere on the dockbar
If that still doesn’t work, you can easily add the icons manually.
check out the files (and their contents) at this location
~/.config/plank/dock1/launchers
and see if you can work it out … if not,let me know.
Just as a matter of interest which version of pcmanfm are you running ?
dpkg -l | grep pcmanfm
chloe@Linux3 ~ $ dpkg -l | grep pcmanfm
ii  pcmanfm                                       1.1.0+bzr914+201307130104~raring1       i386         extremely fast and lightweight file manager
chloe@Linux3 ~ $
Don’t know about you but to be honest this isn’t worth the stress,
I understand I can add the icons manually but if I can’t drag & drop it’s not suitable and I don’t want to waste your time or anyone elses on a 10 page epic trying to get a launcher to do what it’s meant to do in the first place like it does for everybody else
Cairo Dock works ok other than the SSB problem so I can use that for normal applications and place the SSB icons on the desktop
Many thanks
Your call … do you want to keep digging or not ? … I’m easy either way.
If others had reported it I’d want to get to the bottom of it, but as it’s only you …
If others had reported it I'd want to get to the bottom of it, but as it's only you
Your right as I’m the only one with this issue it’s not worth the effort it’s just more frustrating than anything
As it is the only common denominator I can think of between all 3 PC’s that it wont work with is the installation CD and I suppose that can open up a whole can of worms so I think I should gracefully concede defeat unless you can give me an obvious reason why I can only drop 1 SSB into Cairo Dock if not I’ll just leave it as is
Many thanks for you efforts
HOLD ON … I think I’ve cracked this.
It appears it IS to do with the version of libfm and pcmanfm that’s installed by default in Peppermint 4 … I’m running later versions from my personal PPA.
I just want to drop back to the default versions to test.
Already tested on a LiveCD with persistence, and adding my PPA fixed the drag/drop to docky
Gimme half hour … and reinstall docky if you’ve removed it.
Yup it is.
First let me explain something … upgrading to the versions in my PPA solves a LOT of problems, the only 2 NEW problems are
a) manually typing file locations into the pcmanfm address bar for file locations with spaces in their name (and on a network, eg. NAS) can be a bit weird … but BROWSING works perfectly.
(don’t ask me why … but who ever types them in anyway, right :wink: )
b) you’ll have to recreate any pcmanfm bookmarks … as they’re now stored in a different place.
If you want to upgrade to the version in my PPA (and this IS undoable if you don’t like it):
sudo add-apt-repository ppa:mark-pcnetspec/pcmanfm
sudo apt-get dist-upgrade
Now log off, and back on ← this is IMPORTANT to reload the desktop
Now test drag/drop on docky … test it a few times, because it didn’t work the first time I dragged something there … but it did on the third attempt, from then on it works every time. (was probably still starting up).
Sorted
Thank you so much
So was i the only guy on the planet not using your ppa ?
I’m guessing everyone else has either learned to live with it, or doesn’t realise you’re supposed to be able to drag/drop … because nobody else has mentioned it :o
I’m not going to push that version as a Peppermint update due to the NEW issue … even though it’s minor.
If I change the version nobody’s complaining about, you can guarantee they will :wink:
Even if a new version is released that fixes that new issue, just having to recreate the bookmarks would p*ss off as lot of people.
