I’ve set it to 30 mins, but it goes on earlier, which is annoying when watching a documentary/film online. What can I do to make it go off after 30 mins? I’ve set it to that, but it does it earlier- like 10/15 mins.
As you have 2 distros in your signature it would really help when posting a new topic if you mention which one (distro/version/architecture) you’re having the problem with
And … what happens when the “screensaver” goes on … is it a “screensaver”, or does the screen go blank ?
Where exactly did you set it to 30mins ?
Mark sorry yes- forgot to say it’s on the Peppermint laptop. I set it on the screensaver itself. What it is actually doing is just going blank- the screensaver isn’t even coming on now.
I’m on my Mint netbook tonight- so broke can’t afford the heating, so in bed with electric blanket and this netbook.
Next time you’re on Peppermint can you post the output from:
xset -q
I’m going down for a smoko so will do that in a tic. When I went to make a brew before Beethoven was floating around on the screensaver, so odd was working…but yeah it still comes on far more than I set it for!
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ xset -q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 500 repeat rate: 33
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 0 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 0
Colors:
default colormap: 0x20 BlackPixel: 0 WhitePixel: 16777215
Font Path:
/usr/share/fonts/X11/misc,/usr/share/fonts/X11/Type1,built-ins
DPMS (Energy Star):
Standby: 7200 Suspend: 7200 Off: 14400
DPMS is Disabled
run:
gedit ~/.config/autostart/screensaver-settings.desktop
and make it read:
[Desktop Entry]
Name=Screensaver
Comment=Set screensaver timeouts
Exec=xset s 0 0 dpms 0 0 0
SAVE the file.
Log off/on
xset -q
again
Also post the output from:
cat ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
Will do that next time I go downstairs for a smoko ( in a few mins) thanks Mark.
Bit confused by this Mark- sorry not good with computing stuff…
and make it read:[Desktop Entry] Name=Screensaver Comment=Set screensaver timeouts Exec=xset s 0 0 dpms 0 0 0
SAVE the file.
Do you mean in the terminal? Or the page that opens up? I tried pasting that in that page but nothing happened.
Log off/on
Log off the laptop? Then reboot?
We are talking about Peppermint here right ?
if so, what are the contents of the file that opens when you run:
Yes, the Peppermint laptop. Will do that in a bit…
A page opens up saying screen-saver-settings.desktop but I can’t see anything to open.
Hi Melissa
It looks like you typed Marks command wrong you have screen-saver where it should be screensaver
So can you try again this time copy and paste this command into the terminal
if you want to type the command manually please ensure you type the command exactly as written
a text file should pop up highlight & copy the contents and post them back here
Good luck
No-just a white page saying screen saver settings desktop. Nothing to open.
There is no file on your system called
screen saver settings desktop., the file Mark’s looking for is
screensaver-settings.desktop, no space between screen & saver and a dash between screensaver & settings
are you typing the command into the terminal manually or copy and pasting ?
Are you talking about Mint or Peppermint here ?
and what’s the output from:
ls -a ~/.config/autostart
elissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ ls -a ~/.config/autostart
The Peppermint laptop.
Which version of Peppermint ?
What’s the output from:
cat /etc/lsb-release
uname -a
elissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ cat /etc/lsb-release
DISTRIB_ID=Peppermint
DISTRIB_RELEASE=3
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION=“Peppermint Three”
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ uname -a
Linux melissa-HP-Compaq-nx6325-RH628ES-ABU 3.2.0-60-generic #91-Ubuntu SMP Wed Feb 19 03:55:18 UTC 2014 i686 athlon i386 GNU/Linux
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ cat ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
cat: /home/melissa/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml: No such file or directory
I think Peppermint 3 Mark ( one you helped create I think)- it was you who helped me download it onto this laptop about 2 years ago now.
dpkg -l | grep power-manager
