Sorry Mark wasn’t thinking straight, you’re right about the heat
Sorry Emegra, but I’m going to have to call it a night … I need to install PM4 64bit on another PC so I can test some updates before releasing them.
Can we pick this up tomorrow ?
I’ll go through that output tomorrow.
No problem whenever you’re ready I’ve had enough anyway
sorry I took up so much of your time :-[
Not a problem … I wouldn’t be here if I didn’t want to be … catch you tomorrow then
This is for my own reference -
try Wicd … and enable its log for clues.
try disabling IPv6
in light of the DNS issue … try a static IP
try WEP or no security temporarily
try a KNOWN GOOD adapter from another PC … there’s a chance BOTH adapters are screwy.
Because dmesg suggests the adapted is having problems authenticating (so possibly BOTH of them are rubbish) … I’d like to try -
a) a known working adapter from one of the other systems (if possible)
b) giving wicd a shot instead of networkmanager
c) switching to WEP
Which would you like to try first ?
Well from my way of thinking probably changing to a known good network card would give us good info because I could swap with the PC that works best is that ok ?
That’s fine … and makes a lot of sense … it will rule in/out the adapter
OK I swapped the network cards between Linux3 (Which had a good connection) and Linux4 (Which has the bad connection) and there seems to be no difference to Linux3 it still returns a good connection speed (18.17mbps Download & 2.99mbps Upload) only the connection is weaker down to 49% from around 68%
at the moment Linux4 has connected to the network but wont connect to the Internet, it’s showing connected at 43% but it wont open any webpages, I’ve tried rebooting but no luck
First of all … in networkmanager, set
IPv6 “Method” = “Ignore”
Now send the output from:
ping -c 5 173.194.41.99
5 packets transmitted 0 recieved
All 5 attempts end with destination host unreachable
Can you ping your routers IP
ping -c 5 <IP.of.your.router>
No I get exactly the same results
if it means anything I installed another OS on another drive on that PC and wont connect to the Internet either
back in 5 minutes going outside to cool down a bit and have a vape, it’s like a fu@@@ng sauna in here
it's like a fu@@@ng sauna in here
Tell me about it :o
What’s the output from:
sudo lshw -C network
iwconfig
iwlist scanning
rfkill list
pat@Linux4 ~ $ sudo lshw -C network
[sudo] password for pat:
*-network:0
product: RTL-8139/8139C/8139C+
physical id: 9
bus info: pci@0000:00:09.0
logical name: eth0
version: 10
serial: 00:e0:4c:39:22:53
capacity: 100Mbit/s
width: 32 bits
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
resources: irq:17 ioport:ec00(size=256) memory:e6010000-e60100ff
*-network:1
product: AR922X Wireless Network Adapter
vendor: Atheros Communications Inc.
physical id: f
bus info: pci@0000:00:0f.0
logical name: wlan3
version: 01
serial: d8:5d:4c:f6:44:aa
width: 32 bits
clock: 66MHz
capabilities: pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=3.9.0-030900-generic firmware=N/A ip=192.168.2.3 latency=168 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:19 memory:e6000000-e600ffff
pat@Linux4 ~ $ iwconfig
wlan3 IEEE 802.11bgn ESSID:“Network Emegra”
Mode:Managed Frequency:2.437 GHz Access Point: 74:44:01:FA:1A:B8
Bit Rate=2 Mb/s Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=39/70 Signal level=-71 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:10 Invalid misc:2 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.
pat@Linux4 ~ $ iwlist scanning
wlan3 Scan completed :
Cell 01 - Address: 00:8E:F2:BA:01:02
Channel:11
Quality=24/70 Signal level=-86 dBm
Encryption key:on
ESSID:“virginmedia5139198”
24 Mb/s; 36 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000019926f729bf
Extra: Last beacon: 5372ms ago
IE: Unknown: 001276697267696E6D6564696135313339313938
IE: Unknown: 03010B
IE: Unknown: 2A0100
IE: Unknown: 2F0100
Group Cipher : TKIP
IE: Unknown: 32040C121860
IE: Unknown: 2D1AFC181BFFFF000000000000000000000000000000000000000000
IE: Unknown: 3D160B080000000000000000000000000000000000000000
IE: Unknown: DD7E0050F204104A0001101044000102103B00010310470010DB7DC3A2BAC92958883C27166A01D415102100074E657467656172102300074E6574676561721024000631323334353610420007303030303030311054000800060050F20400011011000743473331303144100800022008103C0001011049000600372A000120
IE: Unknown: DD090010180200F02C0000
IE: WPA Version 1
Group Cipher : TKIP
Cell 02 - Address: 74:44:01:FA:1A:B8
Channel:6
Quality=44/70 Signal level=-66 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000027aa278368
IE: Unknown: 000E4E6574776F726B20456D65677261
IE: Unknown: 030106
IE: Unknown: 2A0100
IE: Unknown: 2F0100
Group Cipher : TKIP
IE: Unknown: 2D1AFE181BFFFF000001000000000000000000000000000000000000
IE: Unknown: 3D1606051F00000000000000000000000000000000000000
IE: Unknown: DD7E0050F204104A0001101044000102103B000103104700107D70BC53E951030A126C5E8F3C161C26102100074E657467656172102300074E6574676561721024000631323334353610420007303030303030311054000800060050F204000110110007564D4447343835100800022008103C0001011049000600372A000120
IE: Unknown: DD090010180203F02C0000
IE: WPA Version 1
Group Cipher : TKIP
pat@Linux4 ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
pat@Linux4 ~ $
I’m a bit baffled by this
logical name: [b]wlan3[/b]
Why is it being named 3 not 0
Can you post the contents of:
gedit /etc/udev/rules.d/70-persistent-net.rules
Why is it being named 3 not 0I noticed that as well, I don't know it's only showing 1 network connection in the network manager
and the output from
lspci -vnn | grep -i net
PCI device 0x10ec:/sys/devices/pci0000:00/0000:00:09.0 (8139too)
SUBSYSTEM==“net”, ACTION==“add”, DRIVERS==“?", ATTR{address}==“00:e0:4c:39:22:53”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="eth”, NAME=“eth0”
USB device 0x050d:0x705c (usb)
SUBSYSTEM==“net”, ACTION==“add”, DRIVERS==“?", ATTR{address}==“00:11:50:b2:ca:89”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="wlan”, NAME=“wlan0”
PCI device 0x1814:/sys/devices/pci0000:00/0000:00:0a.0 (rt2800pci)
SUBSYSTEM==“net”, ACTION==“add”, DRIVERS==“?", ATTR{address}==“c8:3a:35:c0:6d:57”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="wlan”, NAME=“wlan1”
USB device 0x148f:0x5370 (usb)
SUBSYSTEM==“net”, ACTION==“add”, DRIVERS==“?", ATTR{address}==“c8:3a:35:ca:0e:df”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="wlan”, NAME=“wlan2”
PCI device 0x168c:/sys/devices/pci0000:00/0000:00:0f.0 (ath9k)
SUBSYSTEM==“net”, ACTION==“add”, DRIVERS==“?", ATTR{address}==“d8:5d:4c:f6:44:aa”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="wlan”, NAME=“wlan3”
and the output from:
