Wifi dropouts
Hi All
Having sorted (after a fashion) my Dell D520 heating issues, I now have an intermittent problem with the wifi dropping out randomly.
General use, such as using this site/surfing, the wifi is stable. Viewing video however the wifi can, and does, drop out frequently but with no set pattern. Youtube clips seem particularly afflicted.
With the lappy near the router I get full signal strength, in another room approx 50% signal strength but the dropouts occur no matter where.
Running Zorin 9 OS, if that helps.
Any advice would be welcome!
Thanks in advance
Rich
You still using the internal ‘intel’ wifi adapter ?
What’s the output from:
sudo lshw -C network
iwconfig
As requested
richard@richard-Latitude-D520:~$ sudo lshw -C network
[sudo] password for richard:
*-network
product: PRO/Wireless 3945ABG [Golan] Network Connection
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:0c:00.0
logical name: wlan0
version: 02
serial: 00:18:de:aa:9b:10
width: 32 bits
configuration: broadcast=yes driver=iwl3945 driverversion=3.13.0-40-generic firmware=15.32.2.9 ip=192.168.0.5 latency=0 link=yes multicast=yes wireless=IEEE 802.11abg
resources: irq:42 memory:efdff000-efdfffff
*-network
product: BCM4401-B0 100Base-TX
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:15:c5:b3:de:44
capacity: 100Mbit/s
width: 32 bits
capabilities: pm bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=b44 driverversion=2.0 duplex=half latency=64 link=no multicast=yes port=twisted pair speed=10Mbit/s
resources: irq:17 memory:efcfe000-efcfffff
richard@richard-Latitude-D520:~$ iwconfig
wlan0 IEEE 802.11abg ESSID:
Mode:Managed Frequency:2.437 GHz Access Point: A0:21:B7:F6:B6:74
Bit Rate=48 Mb/s Tx-Power=15 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=37/70 Signal level=-73 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:101 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.
With reference back to the heating up issues -
iwconfig figures are unaltered (Tx power is ‘as it comes’) - I found changing the parameters made no appreciable difference to the lappy temperatures and the dropping out of wifi is the same whatever the power settings are. I just run the fan manually as and when needed and that works ok re the heat.
Rich
Can’t see any useful driver parameters for iwl3945
Maybe making sure your router is on a channel nobody else around you is using will help … what’s the output from:
sudo iwlist scanning
But if this is a machine that often gets used elsewhere, you’d probably just be better off getting a USB wireless adapter (maybe a “nano” adapter).
According to this posting of yours:
http://linuxforums.org.uk/index.php?topic=12210.msg99400#msg99400
power management for that card was ON but now it’s OFF … so something has changed ???
Run:
sudo iwconfig wlan0 txpower auto
sudo iwconfig wlan0 power on
now what’s the output from:
iwconfig
@ Mark
Maybe making sure your router is on a channel nobody else around you is using will help … what’s the output from: sudo iwlist scanning
richard@richard-Latitude-D520:~$ sudo iwlist scanning
wlan0 Scan completed :
Cell 01 - Address: A0:21:B7:F6:B6:74
Channel:6
Quality=70/70 Signal level=-35 dBm
Encryption key:on
ESSID:“virginmedia6365863”
24 Mb/s; 36 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000000adc57fcb26
Extra: Last beacon: 20ms ago
IE: Unknown: 001276697267696E6D6564696136333635383633
IE: Unknown: 030106
IE: Unknown: 2A0100
IE: Unknown: 2F0100
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
IE: Unknown: 32040C121860
IE: Unknown: 2D1AFC181BFFFF000000000000000000000000000000000000000000
IE: Unknown: 3D1606001300000000000000000000000000000000000000
IE: Unknown: DD7B0050F204104A0001101044000102103B00010310470010AADAE31B9373E44C5152F444735EBAEF102100074E657467656172102300074E6574676561721024000631323334353610420007303030303030311054000800060050F204000110110004686F6D65100800022008103C0001011049000600372A000120
IE: Unknown: DD090010180201F02C0000
Cell 02 - Address: 22:03:D8:0E:CB:62
Channel:1
Quality=29/70 Signal level=-81 dBm
Encryption key:on
ESSID:“BTWifi-X”
9 Mb/s; 12 Mb/s; 18 Mb/s
Mode:Master
Extra:tsf=0000000db9e46d1f
Extra: Last beacon: 24ms ago
IE: Unknown: 00084254576966692D58
IE: Unknown: 030101
IE: Unknown: 2A0100
Group Cipher : TKIP
Authentication Suites (1) : 802.1x
Preauthentication Supported
IE: Unknown: 32043048606C
IE: Unknown: 2D1AAC011BFFFF000000000000000000000000000000000000000000
IE: Unknown: 3D1601080000000000000000000000000000000000000000
IE: Unknown: 7F0101
IE: WPA Version 1
Group Cipher : TKIP
IE: Unknown: DD180050F20201018E0003A4000027A4000042435E0062322F00
Cell 03 - Address: 00:8A:AE:8F:A0:A2
Channel:1
Quality=19/70 Signal level=-91 dBm
Encryption key:on
ESSID:“BTHub5-P8MR”
Mode:Master
Extra:tsf=0000007479639180
Extra: Last beacon: 9848ms ago
IE: Unknown: 000B4254487562352D50384D52
IE: Unknown: 030101
IE: Unknown: 050402030000
IE: Unknown: 0706474220010D14
IE: Unknown: 2A0100
Group Cipher : TKIP
IE: Unknown: 2D1AAC011BFFFF000000000000000000008000000000000000000000
IE: Unknown: 3D1601080400000000000000000000000000000000000000
IE: Unknown: 7F080100000000000040
IE: Unknown: DD2C0050F204104A0001101044000102105700010010470010A5272440C2AB51E59EFEC53E5E100D63103C000101
Cell 04 - Address: C4:10:8A:16:8F:E9
Channel:1
Quality=22/70 Signal level=-88 dBm
Encryption key:on
ESSID:“StMaxentius”
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
Mode:Master
Extra:tsf=00000000a9eadbd1
IE: Unknown: 000B53744D6178656E74697573
IE: Unknown: 010482848B96
IE: Unknown: 030101
IE: Unknown: 2A0100
IE: Unknown: 32080C1218243048606C
IE: Unknown: DD180050F20201018F0003A4000027A4000042435E0062322F00
IE: Unknown: DD1E00904C334C101BFFFF000000000000000000001000000000000000000000
IE: Unknown: 2D1A4C101BFFFF000000000000000000001000000000000000000000
IE: Unknown: DD1A00904C3401080000000000000000000000000000000000000000
IE: Unknown: DD080013920100018500
Group Cipher : TKIP
Cell 05 - Address: 02:03:D8:0E:CB:62
Channel:1
Encryption key:off
ESSID:“BTWifi-with-FON”
Mode:Master
Extra:tsf=0000000db9e51ad5
IE: Unknown: 000F4254576966692D776974682D464F4E
IE: Unknown: 030101
IE: Unknown: 2A0100
IE: Unknown: 7F0101
Cell 06 - Address: 00:03:D8:0E:CB:62
Channel:1
Quality=28/70 Signal level=-82 dBm
Encryption key:on
ESSID:“BTHub3-7CWX”
Mode:Master
Extra:tsf=0000000db9e4f84a
IE: Unknown: 000B4254487562332D37435758
IE: Unknown: 030101
IE: Unknown: 2A0100
Group Cipher : TKIP
IE: Unknown: 7F0101
IE: WPA Version 1
Group Cipher : TKIP
IE: Unknown: DDA70050F204104A000110104400010210570001001041000100103B00010310470010565AA94967C14C0EAA8FF349E6F5931110210002425410230017486F6D652048756220332E30204D756C7469204D6F646510240010425420486F6D652048756220332E3041104200122B3036383232372B4E5132343630303638311054000800060050F204000110110010425420486F6D652048756220332E3041100800020084103C000101
Cell 07 - Address: 32:8A:AE:8F:A0:A2
Channel:1
Encryption key:off
Mode:Master
Extra:tsf=0000007479654384
IE: Unknown: 030101
IE: Unknown: 2A0100
Cell 08 - Address: 3C:81:D8:B2:FF:0F
Channel:11
Encryption key:on
ESSID:“SKY2FF0E”
Mode:Master
Extra:tsf=0000000714bc274f
IE: Unknown: 0008534B593246463045
IE: Unknown: 03010B
IE: Unknown: 2A0104
IE: Unknown: 2F0104
Group Cipher : TKIP
IE: Unknown: 3D160B000400000000000000000000000000000000000000
IE: Unknown: DD760050F204104A0001101044000102103B000103104700108607ECDE10C005248F70D202551FFA021021000842726F6164636F6D1023000842726F6164636F6D1024000631323334353610420004313233341054000800060050F20400011011000A42726F6164636F6D4150100800020084103C000101
IE: Unknown: DD090010180208F02C0000
IE: WPA Version 1
Group Cipher : TKIP
Cell 09 - Address: 00:8A:AE:D3:AB:A5
Channel:48
Frequency:5.24 GHz (Channel 48)
Encryption key:on
ESSID:“BTHub5-NKJH”
Mode:Master
Extra:tsf=0000009fb1715dd7
IE: Unknown: 000B4254487562352D4E4B4A48
IE: Unknown: 01088C129824B048606C
IE: Unknown: 030130
IE: Unknown: 073C4742202401142801142C01143001143401143801143C011440011464011B68011B6C011B70011B74011B78011B7C011B80011B84011B88011B8C011B
IE: Unknown: 200103
Group Cipher : TKIP
IE: Unknown: 2D1A6F111BFFFFFF0000000000000000008000000000000000000000
IE: Unknown: 3D16300F0600000000000000000000000000000000000000
IE: Unknown: 7F080000000000000040
IE: Unknown: BF0C32018033CAFF0000EAFF0000
IE: Unknown: C005012A00FCFF
IE: Unknown: C30402D8D8D8
IE: Unknown: DD8E0050F204104A000110104400010210570001001041000100103B00010310470010DD064409D37E53619406ADDC97F2E82810210002425410230005487562203510240009425420487562203541104200122B3036383334332B4E5134313234373233321054000800060050F204000110110010425420486F6D652048756220352E3041100800020084103C000102
Cell 10 - Address: 22:8A:AE:D3:AB:A5
Channel:48
Encryption key:on
ESSID:“BTWifi-X”
Mode:Master
Extra:tsf=0000009fb1716906
IE: Unknown: 030130
IE: Unknown: 200103
Group Cipher : TKIP
IE: WPA Version 1
Group Cipher : TKIP
then -
wlan0 IEEE 802.11abg ESSID:“virginmedia6365863”
Bit Rate=54 Mb/s Tx-Power=15 dBm
Power Management:on
Link Quality=65/70 Signal level=-45 dBm
Tx excessive retries:26 Invalid misc:340 Missed beacon:0
This lappy is only ever used at home. Re: power management - will the settings now made survive a reboot? If not, how can I make them stick?
Rich
EDIT: I’ve just discovered the power settings don’t survive -
Link Quality=69/70 Signal level=-41 dBm
Tx excessive retries:0 Invalid misc:3 Missed beacon:0
OK, you’re already the only router on channel 6 … might be worth checking your router doesn’t select the channel automatically though.
Power management - You could add the line
to
/etc/rc.local
just above the
exit 0
line
but there’s no point if it doesn’t help … if you manually run:
then use wireless, does it still drop out or not ?
Thanks
Rich
Hmmm… Ran the lappy for a couple of hours or so without issue and viewed several youtube videos ok. Then, wireless dropped out (but immediately re-connected) and when I checked iwconfig, the power management was ‘off’. :o
No idea why…
I seriously doubt if you’re gonna win a fight with this adapter … why not just get a USB adapter ?
I think you are fighting with your power saving setup.
I had a lappy where the wireless did not like any form of power saving.
While your /etc/rc.local is only useful for after boot up, this still leaves it open for other things to meddle with.
I had to hack the file responsible for switching the wireless power saving mode to be the same regardless of the state.
I will look through my notes if I can find how I did it.
Ok fellas - your help greatly appreciated as ever! :wink:
You could try to disable power save mode for wireless:
Create a file named wireless-pm (or similar) in /etc/pm/config.d with the entry:
HOOK_BLACKLIST=“wireless”
This is not what I used before but worth the shot
Found my notes.
Edit as root
/usr/lib/pm-utils/power.d/wireless
Change the following (near end of file):
case $1 in
true) wireless_powersave on ;;
false) wireless_powersave off ;;
*) exit $NA ;;
esac
to:
case $1 in
true) wireless_powersave off ;;
*) exit $NA ;;
esac
Sot that regardless the state (true or false) the wireless powersaving is off.
Thanks SeZo - I can navigate to the file ok and edit the entry but it won’t allow me to save the file (read only). Using sudo gedit in terminal returns ‘no such file or directory’. Obviously, I’m using the wrong command - any thoughts?
You are probably correct! But I am like a dog with a bone and like to exhaust every possibility… ;D
For the first of SeZo’s instructions:
sudo gedit /etc/pm/config.d/wireless-pm
make it read:
HOOK_BLACKLIST="wireless"
SAVE the file.
For SeZo’s second instructions:
sudo gedit /usr/lib/pm-utils/power.d/wireless
make the changes he suggests … SAVE the file.
In either case, probably best to reboot after making the changes
Mark and SeZo - thanks again!
The changes seem to have worked this time - I’ll monitor over a day or two and report back :wink:
Rich
Hi Mark and SeZo
I’ve tested the wifi after making the changes you both recommended. While there has been an improvement in connectivity, the wifi still drops out from time to time - even when sat next to the router and showing a 100% signal… ??? So…
As per Mark’s advice here -
I wouldn’t worry about it too much … but if disabling the wireless cools it down, you could always look into a different wireless card or a “nano” USB wireless adapter such as one of these:
http://www.amazon.co.uk/Edimax-EW-7811UN-150Mbps-Wireless-Adapter/dp/B003MTTJOY/ref=sr_1_1?ie=UTF8&qid=1417120404&sr=8-1&keywords=edimax+nano
I’ve purchased a nano and have it fitted. However… the device is not recognised. I’ve disabled the onboard wireless as per the nano instructions but (I’m guessing here) it needs a driver? The cd supplied is a mini one and doesn’t fit the player. Could you please advise as to downloading and configuring the necessary?
Also, with reference to this -
Re: Dell laptop fan
« Reply #25 on: November 22, 2014, 12:58:10 pm »
Most likely the wireless card … but using ethernet probably won’t make a difference as the card is still powered (even with the wireless hardware switch set to off) on most laptops.
I assume that the only way I can prevent the wireless card from heating up (even when it’s disabled) is by removing it from the lappy? If I do remove it (provided the nano works) will this affect connectivity through an ethernet cable, or are the two methods separate ?
Thanks again for all the help :wink:
Rich
EDIT: Lappy is currently connected via ethernet cable
Removing the onboard wireless adapter won’t interfere with the wired adapter, but let’s get the nano working first.
lsusb
rfkill list
iwconfig
iwlist scanning
Did you want the wireless card enabling for the ‘iwlist scanning’ command?
With an active (cabled) internet connection … Open a terminal and run these commands in sequence:
mkdir ~/8192cu-driver
cd ~/8192cu-driver
wget https://dl.dropboxusercontent.com/u/11876059/rtl8192cu-fixed-for-313.tar.gz
tar xvf rtl8192cu-fixed-for-313.tar.gz
cd ~/8192cu-driver/rtl8192cu-fixed-for-313
make
sudo make install
sudo modprobe -r rtl8192cu
sudo modprobe 8192cu
Did wireless spring to life ?
If so, this probably won’t survive a reboot … but as long as wireless worked, we can then blacklist the conflicting driver (rtl8192cu).
